| Product(s): | Exor Information Manager | ||
| Version(s): | 04.05.00.01 | ||
| Area: | Other | ||
| Subarea: | N/A |
How to change the MapViewer host details in IM4 applications, for example if the MapViewer server changes.
Query back Product Options with Product IM and check the map related options, especially
Log onto application builder. The URL for this is the same as your Apex application, but using page 4500 instead, e.g. https://apexserver.bentley.com/my_apex/f?p=510:1 changes to https://apexserver.bentley.com/my_apex/f?p=4500. You will be prompted to enter:
Select the Worktray application you want to work on.
| Original Author: | Sarah Williams |
