| Product(s): | Exor Information Manager | ||
| Version(s): | 4.5.0.0 | ||
| Area: | Pods | ||
| Subarea: | N/A |
Trying to search for an enquiry using the Pod 'Find Enquiry'. However, after entering a search term, the following error message appears:
ORA-00904 "C061" invalid identifier
The error is due to a limitation on the number of columns displayed within IM4 (60 fields). The number of columns needs to be reduced in order for the search to return results successfully. In order to adjust the number of fields, following the instructions below:
| Original Author: | Fezan Khan |
