| Product(s): | Exor Information Manager (Work Order Work Tray) | ||
| Version(s): | 04.05.00.00 | ||
| Area: | Pod Results Drill Down | ||
| Subarea: | N/A |
ORA-20000: HIG-0067: Record not found: nm_themes_all (NTH_PK) nth_theme_id =>
Click a bar on the Work Orders Awaiting Instruction graph to drill down into the report of the affected work orders. The report screen appears but no report details are shown, just the error message ORA-20000: HIG-0067: Record not found: nm_themes_all (NTH_PK) nth_theme_id =>
Check product option SDOWOLNTH has been set to the correct theme ID. To find the theme ID, go into SQL*Plus and execute the query
select nth_theme_id
from nm_themes_all
where nth_theme_name = 'WORK_ORDER_LINES_TAB';
n/a
| Original Author: | Sarah Williams |
