| Product(s): | Exor Maintenance Manager | ||
| Version(s): | 04.05.00.00 | ||
| Area: | Loaders - Inspection | ||
| Subarea: | N/A |
When I try to load Inspection files using the Maintenance Manager Inspection loader it fails with
“File(s) Could Not Be Submitted”. Submission Error
Text: “Could not read file content”.
No process is visible in Process Monitor. The file is not transferred into directory on the database.
Transfer to and from the database is disabled in the webutil.cfg configuration file on the Application server.
3. Restart the application server after you have made these changes.
| Original Author: | Sarah Williams |
