| Product(s): | Exor Mapcapture | ||
| Version(s): | 04.05.00.03 | ||
| Area: | Exporting Shapefiles | ||
| Subarea: | |||
| Original Author: | Pano Voudouris, Bentley Technical Support Group | ||
In MCP0200 when clicking on the View Directory button the error message 550 - The System cannot find the path specified is shown. The path shown in the top of the window exists on the server and there is a *.shp file in the folder. The folder permissions are ok (read/write/execute for all users).
The error ‘550 - The System cannot find the path specified’ was ‘originated’ on FTP server. To check it run the SQL command below:
begin
nm3mcp_ftp.MOVE_SHAPEFILES_IN;
end;
and the output is:
ORA-20000: 550-The system cannot find the path specified.
ORA-06512: at "HIGHWAYS.NM3FTP", line 301
ORA-06512: at "HIGHWAYS.NM3FTP", line 279
ORA-06512: at "HIGHWAYS.NM3FTP", line 807
ORA-06512: at "HIGHWAYS.NM3MCP_FTP", line 488
ORA-06512: at line 2
20000. 00000 - "%s"*Cause: The stored procedure 'raise_application_error' was called which causes this error to be generated.
*Action: Correct the problem as described in the error message or contact the application administrator or DBA for more information.
220 FTP_SERVER_NAME
331 Password required for FTP_USER.
230-All connections are monitored
User logged in. Win32 error: The operation completed successfully.
Error details: File system returned an error.
230 End
227 Entering Passive Mode (10,94,142,62,194,92).
LIST MCI/MCI_In/
The issue is related to ftp user account and recreating it (or changing it to another one) on FTP server solves the issue. When everything is fine and running SQL command (above) the output should be:
220 FTP_SERVER
230 User logged in.
227 Entering Passive Mode (10,94,142,62,198,15).
LIST MCI/MCI_In/
125 Data connection already open; Transfer starting.
226 Transfer complete.
