| | Product(s): | Exor Street Gazetteer Manager | |
| | Version(s): | N/A | |
| | Environment: | N/A | |
| | Area: | Organisations and Districts | |
| | Subarea: | N/A | |
Sometimes organisations update their OD information so we need to load their OD files to reflect the changes within Highways or a new organisation wishes to communicate with you
- Establish if the organisation has been uploaded previously.
- To do this go to Street Gazetteer Manager>Data>Organisations and Districts (NSG0110)
- Query the form entering the Organisation Code in the Ref box.
- If a record is returned go to Step 2 otherwise follow the instructions in Step 1 first.
STEP 1 – New Organisation
Add a new record in NSG0110 by entering the Organisation Ref, Organisation Name and Prefix and then Save.
STEP 2 – Updating an Organisation
- Make a note of where the OD xml file has been saved.
- Go to Street Gazetteer Manager > Import >NSG Loader Batches. (module NSG0040).
- Create a batch by clicking the Green + which will add a new line.
- Enter a Name and Save. A batch number will be assigned.
- Click ‘File Selection’ which will bring up the File Selection form.
- Click ‘Copy file to Directory’ and a new window will open.
- Browse to the file you wish to load and click ‘Copy’. The file will be copied into the NSG_DATA folder. Close the window.
- Click the .xml checkbox and select the file you want to load. Note you can add other files at the same time if you wish.
- When you have selected the file(s) you wish to load click ‘Add Selected File(s) to Batch’.
- This will pre validate the file and take you back to the NSG Loader Batch form.
- Click ‘Submit Now’
Once the file(s) have loaded there will be a date/time in the ‘Load Ended’ field. (you will need to requery the form)
Product TechNotes and FAQs
External Links
Bentley LEARN Server
| | Original Author: | Jodie Preston | |
