| Product(s): | Exor Core / Network / Document Manager | ||
| Version(s): | 10.1.2 | ||
| Area: | Application Server | ||
| Subarea: | N/A | ||
File default-web-access.log is taking up too much disk space. Also log files in apache \ logs folder increasing.
Metalink says that you can disable the logging in the default-web-access.log file, by amending the {oracle home}\j2ee\oc4j_bi_forms\config\default-web-site.xml file, commenting out the entry. The format for commenting it out is:
<!-- <access-log path="../log/default-web-access.log" /> -->
This will need a restart though to take effect, so will need doing out of hours.
It is safe to remove the log files from the apache\logs folder.
