| Product(s): | Exor NET Core | ||
| Version(s): | N/A | ||
| Area: | Login | ||
| Subarea: | N/A | ||
User is trying to login to the forms application however receives the following error:
FRM-92101: There was a failure in the Forms Server during startup. This could happen due to invalid configuration.
Please look into the web-server log file for details.
This error could be caused by many things and the first thing to check is if one or all users are experiencing the problem.
If all users are affected then you should check the application server is online and running ok. Also check for any firewall or proxy server changes which may be interrupting connections.
If only one or a select few users are experiencing the error then:
