| Product(s): | Exor Core / Network / Assets Manager/Enquiry Manager | ||
| Version(s): | Any v4 onwards | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
A new user is created but when they try to login they get
HIG-0182 user not instantiated correctly.
Firstly check the user has the HIG_USER role - this is mandatory for all users whatever access you want them to have.
Secondly, log into SQL*Plus as the Highways owner user and run the following SQL, replacing 'USER' with the username of the new user, in capitals and enclosed in single quotes:
SQL> exec nm3context.create_instantiate_user_trig('USER');
If that doesn't work either then contact Support.
Problem 56394
http://communities.bentley.com/products/assetwise/exor/w/wiki/instantiate-user-error
