| | Product(s): | Exor Street Gazetteer Manager | |
| | Version(s): | 04.08.00.00 | |
| | Environment: | N/A | |
| | Area: | Import | |
| | Subarea: | N/A | |
When adding files to an import batch there is an error in the status message field:
- Ensure database parameter utl file dir is not null. Changing this requires the database to be restarted so it will need to be done out of hours. Instructions are here.
- Check privileges on the NSG import directory on the server are set so that anyone can read/write/delete.
- Re-assign Java privileges on the Oracle directories. Instructions are here.
- Remove and re-register the EToN schemas, by running scripts remove_eton_schemas and then register_eton_schemas
| | Original Author: | Sarah Kistulinec | |
