2.6.0.8 Fix 1
 Product(s):Transportation Intelligence Gateway
 Version(s):2.6.0.8 Fix 1
 Environment:N/A
 Area:Patch Release Notes
 Subarea:N/A
Introduction
This document discusses the install/upgrade folder having changes made against defects/enhancements raised by the customers. This document is intended for those who will be involved in implementation of Transportation Intelligence Gateway (TIG) Application version 2.6.0.8
Existing customers will be able to deploy TIG v2.6.0.8 Fix 1 only if they have Base Release of TIG Version 2.6.0.8 installed already.
After reading through this document, if you have any further training or consultancy requirements then please contact your Bentley account manager.
Details
Details Baseline Release
TIG Version 2.6.0.8
Description
Transportation Intelligence Gateway (TIG) version 2.6.0.8 Fix1
Implementation Instructions
Copy tig02060008en_updt1.zip (inside the folder containing this readme file) and paste it on the
Database Server
To perform Install of TIG version 2.6.0.8 Fix1, follow the instructions given in the deployment document TIG_v2.6.0.8_updt1_DeploymentGuide.pdf
Note:  OHS restart is must. We must run TIG Application URL in Compatibility Mode of Internet Explorer. Please refer to Appendix B in TIG_v2.6.0.8_DeploymentGuide.pdf document for more details.
It MUST be communicated to the End User that TIG must run in Compatibility Mode of Internet Explorer.
Limitations
Configuration Information
None
How To Test
Recommend full regression test
Rollback Strategy
Initially implement on a test environment
List of Amended Files
Filename
Version
xna_hpms.pkw
2.14
Log No. Summary
This chapter summarizes all software issues that have been addressed by this fix. For issues raised by users, Bentley Technical Support Group (TSG) Service Request Numbers are cross referenced where applicable. Any future issues will be addressed in latest base release only.
Details
Internal Reference
TSG Service Request
TIG - MP_HUNDREDTHS Extract- Network Attribute MAX_SEGMENT_LENGTH Fails to Compile
Defect 966730
 7001454703
 Original Author:Jon Libby
