| Product(s): | Exor Street Gazetteer Manager | ||
| Version(s): | 4.8 | ||
| Area: | Import | ||
| Subarea: | N/A |
An OD file appeared to run through successfully but on completion the 'successful' and 'unsuccessful' counts were both 0 and no data had been loaded / updated.
Run the file through an XML checker. In this case, the valid values for tag outofhoursarragement should be 0 for NO or 1 for YES but in the file the value was FALSE. Once that was changed, the file loaded successfully.
| Original Author: | Sarah Willis-Culpitt |
