| Product(s): | Exor Network Manager | ||
| Version(s): | 4.8.0.0 | ||
| Area: | Process Framework Manager | ||
| Subarea: |
Alert Manager – runs alerts created in the exor database and sends out batch mails etc. to defined groups of users.
Core Housekeeping – clears down a temporary table, HIG_ROUTER_PARAMS, populated when forms are used. Clears down the table daily.
Group of Groups Theme Refresh – When a theme is created, you can defer immediate changes to the theme using a configuration flag. Running this procedure will update all Group of Groups themes with the Update on Edit flag set to ‘D’ or ‘Deferred’.
Load Document Bundles – Used by Document Manager (Not Installed at BCMOTI) to automatically load document files into the Exor database. The code executed can be found in the package DOC_BUNDLE_LOADER.
Refresh Auto-generated Passwords – refreshes system generated passwords.
Route Materialized View Refresh – updates and runs statistics on materialized views. This process maintains materialized view, V_OBJ_ON_ROUTE. It is a snapshot table for all assets on a section. It also maintains V_GEOM_ON_ROUTE, a snapshot of all geometries of the road_sections layer. These processes are used by Bentley Mapcapture.
| Original Author: | Jon Libby |
