| Product(s): | Exor TMA API and Web Service | ||
| Version(s): | 04.05.00.00 | ||
| Area: | Install/Upgrade | ||
| Subarea: | N/A |
Some organisations operate a secure web service which is over and above the security defined in EToN. This will stop users sending a notice to these organisations until the recipients SSL certifcate is imported into Oracle. When a secure web service is in use, the notice URL will usually be prefixed with HTTPS:// rather than HTTP://
Download the following file which contains the nessesary instructions and files.
Please note you need to be logged into Communities to download the file. If the Download button doesn't appear after you've clicked the link below, you can login by clicking the small 'person' icon in the top right, then the login is the same as you use to log Cases. You can also create an account even if you do not currently have access to create Cases.
http://communities.bentley.com/products/assetwise/exor/m/mediagallery/269444.aspx
| Original Author: | Lee Jackson |
