How to...
The “How to…” page section of BECS Wiki has been created to help to orientate and facilitate BECS users work in the whole process of BECS installation, solution implementation or administration.
BECS is very easy, intuitive non-programming and user-friendly visual integration modeling environment. BECS is essentially an integration bus with wide range of features, connectors and integration functionality. This functionality includes an ability to create and use native "connectors" to variety of external enterprise applications, such as SAP®, Maximo®, Oracle® and many others. BECS is fully certified for SAP® ERP as well as SAP® HANA integration. This visual integration platform is the preferred way how to automate the flow of data between Bentley applications and external enterprise applications to provide two-way communications for data creation, updates, and modifications, keeping the data in both systems accurate and up to date.
This “How To…” site consists of three subsections/subpages dedicated to particular steps in a BECS integration project, according to different roles. On these pages the BECS user will find not only BECS documentation but also video guides or other helpful documents with a download section always at the bottom of pages.
We are happy you've decided to use BECS and therefore use the opportunity to meet all its benefits. Your BECS integration implementation project consists of these four phases:
The “How to…” section will help and guide the BECS user through the first three phases, depending on the user's role in the project phases. The fourth step is already in whole productive environment. Every subsection of these sections has the same structure:
How to install BECS
will help you install BECS on the integration server, guiding you through the BECS installation and its prerequisites step by step and how to check the successful installation.
How to implement BECS solution
will bring you information how to use BECS platform to design, customize and test an integration solution that meets the user's requirements. This section explains every BECS platform feature and technique in a way of simple complete text guide and videos of major features “live”.
How to admin implemented BECS solution
will guide you through standard BECS solution administration - routine management, maintenance, and checking the successful running of BECS integration solution and how to solve the most common problems. The BECS administrator has a knowledge of the solution architecture.
