BECS Service Back-End
The BECS Service Back-End section is focused in two major issues:
Solution Application Back-End
This background architecture component is designed for data retrieving and has 2 major set of services:
Solution Application Front-End
To allow usage on wider range of users application Front-end will be prepared to support following devices:
Application Architecture
