BECS Features - Videos
The aim of the prepared "BECS Features Videos" page is to introduce possible BECS features through creating a simple application step by step.
In subsequent videos we will use several BECS functions, which in the created application allow to enter the Asset Number via the BECS ED WebPortal and which will be subsequently uploaded from SAP, stored in local SQL and sent to be displayed (in another window of the same BECS ED WebPortal) in another system for processing via Rabbit MQ in a transformed format using a small post processing procedure.
Afterwards, it will be possible to start the same project by sending a message to the input MSMQ.
Appearance of the final application
The BECS Features videos below are following each other and therefore for a proper understanding it is needed to always understand the mission and outcome of the previous one video.​​​​​​​
