BECS Packaged Integration for PlantSight via Interop integrates PlantSight (PS) with external enterprise systems or Bentley products via CCOM messages and adapting all possible individual requirements provided that the CCOM is properly defined and correctly processed in Interop, Data Hub and Data Reader.
Integration direction:
This CCOM oriented integration supports bi-directional way of data transfer – BECS can publish CCOM into the Interop as well as subscribe for CCOMs from Interop.
Main features:
Requirements:
BECS Packaged Integration for PS via Interop ready to use packages:
These integration packages include pre-defined and ready to use integration projects covering the implemented workflows between the PlantSight and different enterprise systems, e.g. for:
In case you have not find your system or integration project, please contact the BECS team.
