BECS Dynamic Packaged Integration for PlantSight PiP
BECS Dynamic Packaged Integration for PlantSight PiP is the easiest way how to show data from external system in form of well formatted BECS web page as “external links” or “Picture in Picture view” in PlantSight (PS). Integration is using BECS Web Content Generator. Data are dynamically loaded to PlantSight Picture in Picture by BECS without any saving on PlantSight side.
Integration direction:
This integration supports bi-directional way of data transfer directly to PlantSight PiP.
Main features:
BECS Dynamic Packaged Integration for PS PiP ready to use packages:
These integration packages include pre-defined and ready to use integration projects covering the implemented workflows between the PlantSight and different enterprise systems, e.g. for:
In case you have not find your system or integration project, please contact the BECS team.
Videos
The video below shows BECS dynamic integration with PlantSight by using generated BECS Web Content via URL link (SAP data and OPC system):
The video below shows dynamic integration between PlantSight and MS SharePoint by BECS.
