BECS Dynamic Packaged Integration for PlantSight GUI enables to easily integrate any PlantSight (PS) solution with external enterprise systems or other Bentley products with no need of any activity, configuration or modification on PlantSight side. This package actually implements not only all necessary components to define, adapt and maintain integration, but also enables a simple methodology, how to visually create new BECS integration project to connect any enterprise system on fly.
BECS Dynamic Packaged Integration for PS GUI enables to show data on fly from integrated enterprise systems in PlantSight live Properties window, in MultiLine Tables and also in Visual Filter.
Integration direction:
This integration supports one-way data visualization from different external enterprise systems or other Bentley products.
Main features:
Architecture of BECS Dynamic Packaged Integration
BECS solution architecture for PlantSight includes these steps:
BECS Selection Console
BECS Selection Console, as a part of BECS Dynamic Packaged Integration for PS GUI, is a native BECS web administration portal enabling user to easily set up the mapping of integrated systems and their parameters displayed in PlantSight, e.g.:
BECS Dynamic Packaged Integration for PS GUI ready to use packages
These integration packages include pre-defined and ready to use integration projects covering the implemented workflows between the PlantSight and different enterprise systems, e.g. for:
In case you have not find your system or integration project, please contact the BECS team.
Videos
The video below shows the main features of BECS Dynamic Packaged Integration used in PlantSight - how to visually integrate without any hard-coding or modification on PlantSight side with any enterprise systems or its combinations.
In this example data are dynamically loaded to PlantSight Properties window from the selected systems (SAP, Maximo, APM/AR, ALIM,…) by BECS without any saving on PlantSight side. BECS also generates on fly multiline tables (SAP Work Orders, SharePoint documents, ALIM documents, AR/APM alarms,…) to the selected element in PlantSight. Visual Filtering in PlantSight by BECS dynamic data retrieve enables to filter across external enterprise systems within one filtering condition, e.g. attribute name from SAP (Manufacturer,…), approved construction in SharePoint, approval status in ALIM and coloring by selected attribute (e.g. country of manufacturer, acquisition date,…) at the same time. Data are always fresh and taken directly from source systems and displayed without any saving. BECS mapping console enables to add any new system to PlantSight Properties window or selection and adding the attributes for Multiline Tables or Visual Filtering without no need of programming.
The video below shows how to create new BECS DataReading Project in BECS for integrating new BECS Dynamic Packaged Integration with new enterprise system.
The video below shows a simple step-by-step guide how to add new BECS DataReading Project into PlantSight solution.
In the document below, you can find a step-by-step guide how to configure BECS DPI for PlantSight:
Configuration Guide for BECS Dynamic Packaged Integration for PlantSight
