BECS Packaged Integration for PlantSight via DataHub directly
BECS Packaged Integration for PlantSight via DataHub directly is the integration package with pre-defined integration processes for direct writing to DataHub. In practice BECS is creating relevant DataHub object directly from external user information system with no need of using predefined schema or CCOM formatted message. Thanks to this DataHub object creation user can see automatically created tab in PlantSight (PS) visualizer window.
Integration direction:
This integration supports one-way data transfer from integrated system to PlantSight via DataHub.
Main features:
    • System-oriented integration
    • Data of external user systems redundantly saved in Data Hub
    • Asynchronous integration
    • Dynamically created tabs in PlantSight from Data Reader
Requirements:
    • Fully functional Data Hub and Data Reader services
BECS Packaged Integration for PS via DataHub ready to use packages
These integration packages include pre-defined and ready to use integration projects covering the implemented workflows between the PlantSight and different enterprise systems, e.g. for:
    • SAP
      • Read SAP FLOC details
      • Read SAP EQ details
      • Read SAP Work Orders
      • Read SAP Notifications
      • Read SAP Maintenance Plans
    • IBM Maximo
      • Read Maximo Assets details
      • Read Maximo Work Orders
      • Read Maximo Job Plans
    • Oracle eAM
      • Read Oracle Assets details
      • Read Oracle Work Orders
      • Read Oracle Planned Works
    • MS SharePoint 365
      • Read MS SharePoint 365 documents
      • Read MS SharePoint 365 document attributes
    • Documentum
      • Read Documentum documents
      • Read Documentum document attributes
    • OpenText​​​​​​​
      • Read OpenText documents
      • Read OpenText document attributes
In case you have not find your system or integration project, please contact the BECS team.
Videos
The videos below show integration where BECS is saving data directly to DataHub and they are processes standard way (via DataReader REST API).​​​​​​​
    • Create new Tab in PlantSight with SAP data by BECS integration
    • Update metadata in PlantSight by BECS integration
