BECS Packaged Integration
Welcome to the BECS Packaged Integration section, where you will find:
Short intro
Bentley Systems has a wide range of great products covering different areas of the company's day-to-day operations (AssetWise Asset Reliability, ALIM, PlantSight, Digital Twins,...). Almost every company uses more than one information system in its daily work, whether from the Bentley product line or third-party system, such as ERP systems (SAP, Maximo,...) as well as DMS systems (SharePoint 365, OpenText,...), GIS systems (ESRI, AutoDesk,…) or SCADA / IoT systems. Therefore, one of the most required topics nowadays is covering the communication and data transfer among these different systems. This communication in Bentley product family with third-party systems is effectively done by BECS integration platform with its wide range of existing integration projects. By combining relevant integration projects, specific BECS Packaged Integrations for connecting Bentley products with third-party products have been created to cover pre-defined workflows bringing significantly more capabilities for users.​​​​​​​
What is BECS Packaged Integration?
BECS Packaged Integration is a solution package designed in BECS Integration Toolkit implementing defined business process, including pre-defined and ready to use BECS integration projects to cover concrete workflows between Bentley products and external enterprise systems (or other Bentley products). To be able to run the integration projects, the BECS Integration Toolkit is bundled with BECS Packaged Integration.
These BECS Packaged Integrations include ready to use integration projects covering the most common workflows, e.g. create, update, install, dismantle, read, attach,…
For more detailed information about BECS Dynamic Packaged Integration (BECS DPI, BDPI) please click here.
Example of BECS Packaged Integration
Let’s see as an example the BECS Packaged Integration for AssetWise ALIM and SAP. This BECS Packaged Integration includes ready to use integration projects covering these workflows:
  1. Create new SAP FLOC from AssetWise ALIM
  2. Update SAP FLOC from AssetWise ALIM
  3. Create new SAP EQ from AssetWise ALIM
  4. Update SAP EQ from AssetWise ALIM
  5. Create AssetWise ALIM SI from SAP EQ
  6. Update AssetWise ALIM SI from SAP EQ
  7. Install AssetWise ALIM SI from SAP EQ
  8. Dismantle AssetWise ALIM SI from SAP EQ
  9. Install SAP EQ from AssetWise ALIM SI
  10. Dismantle SAP EQ from AssetWise ALIM SI
  11. Read SAP FLOC Hierarchy from SAP to AssetWise ALIM
  12. Read SAP Notifications from AssetWise ALIM
  13. Read SAP WO from AssetWise ALIM
  14. Create SAP Notification from AssetWise ALIM
  15. Create SAP WO from ALIM
  16. Attach document to SAP Notification
How to find a required BECS Packaged Integration?
The list of ready to use BECS Packaged Integrations (BPI) and BECS Dynamic Packaged Integrations (BDPI) you can find here.
To select the ready to use BECS Packaged Integration we have created an easy 3-steps wizard (available for BECS Knowledge Center members):
Let's start to find your integration here (available for BECS Knowledge Center members).
In case you have not find the required BECS Packaged Integration or a required integration workflow, please contact the BECS team.
What is included in the BECS Packaged Integration?
What is not included in the BECS Packaged Integration?​
However, the BECS Packaged Integrations have the possibility to adapt all individual requirements depending on specific projects. Of course, these individual requests can be implemented, but they need to be discussed with the responsible team as a subject of non-standard integration project. In case of interest please contact the BECS Team.
