BECS IBM Maximo Connector
About IBM Maximo
Maximo Asset Management by IBM combines asset management with maintenance management. From a single system, companies can monitor and manage the full life cycle of their enterprise assets, including facilities, communications, transportation, production, infrastructure and more. This centralized functionality ensures that users have visibility and control of asset conditions and processes while increasing productivity and lowering downtime.
BECS IBM Maximo Connector enables very easy and quick integration between IBM Maximo and 3rd party systems.
How to use BECS IBM Maximo Connector
This short video shows how to use BECS IBM Maximo connector.
How it works
The next videos show how to work with BECS IBM Maximo connector:
BECS IBM Maximo Connector documentation
How to install BECS IBM Maximo Connector
BECS Maximo Connector prerequisites
BECS Maximo Connector requires:
BECS Maximo connector Installation Procedure
Whole process will drive following steps:
  1. Installation of standard BECS package
  2. After installation (if standard package does not include Maximo Connector), is necessary copy dll file “Ace.Integrator.Maximo.dll”
  3. After installation (if standard package does not include Maximo Connector), is necessary copy dll file “Ace.Integrator.Maximo.dll” to BECS Visual Architect installation path (Architect\Extensions\Application).
  4. Product will be after Activation ready to use.
BECS-IBM-Maximo-Connector-DLL.zip   BECS-Maximo-Connector-documentation.zip
