BECS SYNCHRO Connector
About SYNCHRO
SYNCHRO provides highly interoperable digital technology to drive the construction industry’s evolution from traditional 2D planning and siloed workflows to a highly cooperative and efficient 4D visual planning and VDC project management process. SYNCHRO uniquely provides a single technology solution to create your approach and to accurately visualize, analyze, edit, and track your entire project, including logistics and temporary works. This visual and data-rich environment engages all team members in a transparent process to optimize construction projects of all types, from tendering through construction, commissioning, and handover. The result is sustained improvement, the elimination of waste, and increased value.
BECS SYNCHRO Connector enables very easy and quick integration between SYNCHRO and 3rd party systems. BECS SYNCHRO connector has implemented following set of functions:
Create Task, Create User Field, Change Progress, Manage Task, Get Task, Assign User Field.
How to use BECS SYNCHRO Connector
This short video shows how to use BECS SYNCHRO connector.
How it works
The next videos show how to work with BECS SYNCHRO connector:
BECS SYNCHRO Connector documentation
How to install BECS SYNCHRO Connector
BECS SYNCHRO Connector prerequisites
BECS SYNCHRO connector requires:
BECS SYNCHRO Connector Installation Procedure
Whole process will drive following steps:
  1. Installation of standard BECS package
  2. After installation (if standard package does not include SYNCHRO Connector), is necessary copy dll file “Ace.Integrator.SYNCHRO.dll”, “Ace.Integrator.SYNCHRO.pdb” and “SynchroNET.dll” to BECS installation path.
  3. After installation (if standard package does not include SYNCHRO Connector), is necessary copy dll file “Ace.Integrator.SYNCHRO.dll”, “Ace.Integrator.SYNCHRO.pdb” and “SynchroNET.dll”  to   BECS Visual Architect installation path (Architect\Extensions\Application).
  4. Product will be after Activation ready to use.
BECS-SYNCHRO-Connector-DLL.zip
