BECS Salesforce Connector
About Salesforce
Salesforce is a suite of CRM (Customer Relationship Management) tools designed to help businesses big and small dramatically improve their customer service, retention rates, purchase analysis and much, much more. Salesforce's main services are tools for case, task, and issue management. Utilized by some of the biggest businesses in the world, it’s a highly respected and widely used platform.
BECS Salesforce Connector enables very easy and quick integration between Salesforce and 3rd party systems.
How it works
BECS Salesforce Connector Video
How to install BECS Salesforce Connector
​​​​​BECS Salesforce Connector prerequisites
BECS Salesforce Connector requires:
BECS Salesforce Connector Installation Procedure
Whole process will drive following steps:
  1. Installation of standard BECS package.
  2. After installation (if standard package does not include SalesForce Connector), it is necessary to copy the files from BECS SalesForce Connector DLLs Package ”Ace.Integrator.dll, Ace.Integrator.SalesForce.dll, Ace.Integrator.SalesForce.dll.config, Ace.Integrator.SalesForce.pdb, Microsoft.Bcl.AsyncInterfaces.dll, Microsoft.Bcl.AsyncInterfaces.xml, NetCoreForce.Client.dll, NetCoreForce.Client.xml, NetCoreForce.Models.dll, NetCoreForce.Models.xml, Newtonsoft.Json.dll, Newtonsoft.Json.xml, System.Buffers.dll, System.Buffers.xml, System.Linq.Async.dll, System.Linq.Async.xml, System.Memory.dll, System.Memory.xml, System.Numerics.Vectors.dll, System.Numerics.Vectors.xml, System.Runtime.CompilerServices.Unsafe.dll, System.Runtime.CompilerServices.Unsafe.xml, System.Text.Encodings.Web.dll, System.Text.Encodings.Web.xml, System.Threading.Tasks.Extensions.dll, System.Threading.Tasks.Extensions.xml” to BECS installation path.
  3. After installation (if standard package does not include SalesForce Connector), it is necessary to copy the files from BECS SalesForce Connector DLLs Package ”Ace.Integrator.dll, Ace.Integrator.SalesForce.dll, Ace.Integrator.SalesForce.dll.config, Ace.Integrator.SalesForce.pdb, Microsoft.Bcl.AsyncInterfaces.dll, Microsoft.Bcl.AsyncInterfaces.xml, NetCoreForce.Client.dll, NetCoreForce.Client.xml, NetCoreForce.Models.dll, NetCoreForce.Models.xml, Newtonsoft.Json.dll, Newtonsoft.Json.xml, System.Buffers.dll, System.Buffers.xml, System.Linq.Async.dll, System.Linq.Async.xml, System.Memory.dll, System.Memory.xml, System.Numerics.Vectors.dll, System.Numerics.Vectors.xml, System.Runtime.CompilerServices.Unsafe.dll, System.Runtime.CompilerServices.Unsafe.xml, System.Text.Encodings.Web.dll, System.Text.Encodings.Web.xml, System.Threading.Tasks.Extensions.dll, System.Threading.Tasks.Extensions.xml” to BECS Visual Architect installation path (Architect\Extensions\Application).
  4. Product will be after Activation ready to use.
BECS Salesforce Connector DLL
