About Siemens WebBFS
BECS Siemens WebBFS Connector enables very easy and quick integration between Siemens WebBFS and 3rd party systems. BECS Siemens WebBFS Connector has implemented following set of functions:
Search Object, Read Object, Insert Object.
BECS Siemens WebBFS Connector documentation
How to install BECS Siemens WebBFS Connector
BECS Siemens WebBFS Connector prerequisites
BECS Siemens WebBFS connector requires:
- BECS Server version 5.5 or higher
- BECS Visual Architect version 5.5 or higher
BECS Siemens WebBFS Connector Installation Procedure
Whole process will drive following steps:
- Installation of standard BECS package
- After installation (if standard package does not include Siemens WebBFS Connector), is necessary copy dll file “Ace.Integrator.Siemens.dll” to BECS installation path (..\BECS\Server\Integrator)
- After installation (if standard package does not include Siemens Connector), is necessary copy dll files “Ace.Integrator.Siemens.dll” to BECS Visual Architect installation path (..\BECS\Architect\Extensions\Application)
- This connector requires fully activated BECS server and BECS Visual Architect product.
BECS_5F00_Siemens_5F00_WebBFS_5F00_Connector_5F00_DLLs.zip
