BDPI Deployment
What will you find in BDPI Mastering Deployment section?
Do you need to deploy a new dataReading Project?
All ready to use BDPIs are listed with their details in our Bentley Integration Catalogue. Therefore, to find your BDPI, please, visit this page first to check if the required BDPI already exists or not.
Have you found the required BDPI in Bentley Integration Catalogue?
  • In case, you have found the required BDPI, there is no need to deploy any new BECS dataReading project. Just take it and use it ;-)
Haven't you found the required BDPI in Bentley Integration Catalogue?
  • In case, you have not found the required BDPI, please, contact our team here;
  • or you can deploy a new BECS dataReading Project by yourself. To be able to do it, you need to have skilled knowledge of BECS deployment (ask for more details about BECS Training here).
BECS dataReading Project Deployment Videos
In the videos below you can see how to create a new BECS dataReading project on the example of Excel system...
  • How to create new BECS dataReading Project - Excel
    This video shows how to create a new BECS dataReading Project for integrating a new enterprise system by BDPI on Excel example.
  • How to add a new BECS dataReading Project into PlantSight solution
    This video shows a simple step-by-step guide how to add the new BECS dataReading Project into PlantSight solution by BDPI.
BDPI Deployment Videos Download
