About ProjectWise
ProjectWise is a suite of engineering project collaboration software from Bentley Systems designed for the architecture, engineering, construction, and owners/operator (AECO) industries. It helps project teams design, manage, review, share, and distribute engineering project content all within a single connected data environment (CDE). ProjectWise is a file and vendor agnostic solution capable of managing any type of CAD, BIM, geospatial and project data.
BECS ProjectWise Connector enables very easy and quick integration between ProjectWise and other systems. It has implemented the following set of functions:
BECS ProjectWise Connector Documentation
How to install ProjectWise Connector
BECS ProjectWise Connector Prerequisites
BECS ProjectWise Connector requires:
BECS ProjectWise Connector Installation Procedure
Whole process will drive following steps:
BECS ProjectWise Connector Downloads
