List of ready to use BECS Packaged Integrations / BECS Dynamic Packaged Integrations (for more info contact our team):
BECS Packaged Integration for Oracle Aconex
BECS Packaged Integration for AutoDesk Cloud Construction
BECS Packaged Integration for AssetWise Asset Reliability
AssetWise Asset Reliability / SAP
Bentley Integration Catalogue Code: BPI-AR-SAP
Segment creation from SAP
Segment update from SAP
Asset creation from SAP
Asset update from SAP
Asset installation to Segment from SAP
Asset uninstallation from Segment from SAP
Process Request For Work from AssetWise Asset Reliability
Work Request creation from SAP
Work Request update from SAP
Work Order creation from SAP
Work Order update from SAP
Solution Package creation from SAP
Solution Package update from SAP
AssetWise Asset Reliability / IBM Maximo
Bentley Integration Catalogue Code: BPI-AR-MAXIMO
Segment creation from Maximo
Segment update from Maximo
Asset creation from Maximo
Asset update from Maximo
Asset installation to Segment from Maximo
Asset uninstallation from Segment from Maximo
Work Order creation from Maximo
Work Order update from Maximo
Solution Package creation from Maximo
Solution Package update from Maximo
AssetWise Asset Reliability / Infor
Bentley Integration Catalogue Code: BPI-AR-INFOR
Segment creation from Infor
Segment update from Infor
Asset creation from Infor
Asset update from Infor
Asset installation to Segment from Infor
Asset uninstallation from Segment from Infor
Work Order creation from Infor
Work Order update from Infor
Solution Package creation from Infor
Solution Package update from Infor
AssetWise Asset Reliability / Oracle eAM
Bentley Integration Catalogue Code: BPI-AR-ORACLE
Segment creation from Oracle eAM
Segment update from Oracle eAM
Solution Package creation from Oracle eAM
Solution Package update from Oracle eAM
Work Request creation from Oracle eAM
Work Request update from Oracle eAM
Work Order creation from Oracle eAM
Work Order update from Oracle eAM
BECS Packaged Integration for AssetWise ALIM
AssetWise ALIM / MS SharePoint 365
Bentley Integration Catalogue Code: BPI-ALIM-SHAREPOINT
Upload Document from AssetWise ALIM to MS SharePoint 365
Upload URL to Document in AssetWise ALIM to MS SharePoint 365
Create Document attributes from AssetWise ALIM to MS SharePoint 365
Update Document attributes from AssetWise ALIM to MS SharePoint 365
Update Document from MS SharePoint 365
Update Document attributes from MS SharePoint 365
AssetWise ALIM / Documentum
Bentley Integration Catalogue Code: BPI-ALIM-DOCUMENTUM
Upload document from AssetWise ALIM to Documentum
Update document attributes from AssetWise ALIM to Documentum
Update document from Documentum
Update document attributes from Documentum
Search Documentum content by any attribute filtering condition
FullText Search in Documentum for any file content from AssetWise ALIM
Return list of found documents from Documentum in a form of BECS Web Page
Return list of found documents from Documentum in a form of XML file
CheckOut Documentum document from AssetWise ALIM
CheckIn new revised document with updated attributes from AssetWise ALIM
AssetWise ALIM / OpenText
Bentley Integration Catalogue Code: BPI-ALIM-OPENTEXT
Upload document from AssetWise ALIM to OpenText
Update document attributes from AssetWise ALIM to OpenText
Update AssetWise ALIM Document from OpenText
Update AssetWise ALIM Document attribute from OpenText
AssetWise ALIM / SAP
Bentley Integration Catalogue Code: BPI-ALIM-SAP
Create new SAP FLOC from AssetWise ALIM
Update SAP FLOC from AssetWise ALIM
Read SAP FLOC Hierarchy from SAP to AssetWise ALIM
Create new SAP EQ from AssetWise ALIM
Update SAP EQ from AssetWise ALIM
Create AssetWise ALIM SI from SAP EQ
Update AssetWise ALIM SI from SAP EQ
Install AssetWise ALIM SI from SAP EQ
Dismantle AssetWise ALIM SI from SAP EQ
Install SAP EQ from AssetWise ALIM SI
Dismantle SAP EQ from AssetWise ALIM SI
Read SAP Notifications from AssetWise ALIM
Read SAP WO from AssetWise ALIM
Create SAP Notification from AssetWise ALIM
Create SAP WO from ALIM
Attach document to SAP Notification from ALIM Document
AssetWise ALIM / IBM Maximo
Bentley Integration Catalogue Code: BPI-ALIM-MAXIMO
Create Segment from AssetWise ALIM
Update Segment from AssetWise ALIM
Read Segment Hierarchy from Maximo to AssetWise ALIM
Create Asset from AssetWise ALIM
Update Asset from AssetWise ALIM
Create AssetWise ALIM SI from Maximo Asset
Update AssetWise ALIM SI from Maximo Asset
Install AssetWise ALIM SI from Maximo Asset
Dismantle AssetWise ALIM SI from Maximo Asset
Install Maximo Asset from AssetWise ALIM SI
Dismantle Maximo Asset from AssetWise ALIM SI
Read WO from AssetWise ALIM
Create WO from AssetWise ALIM
AssetWise ALIM / Oracle eAM
Create Oracle eAM Segment from AssetWise ALIM
Update Oracle eAM Segment from AssetWise ALIM
Read Asset Hierarchy from Oracle eAM to AssetWise ALIM
Create Oracle eAM Asset from AssetWise ALIM
Update Oracle eAM Asset from AssetWise ALIM
Create AssetWise ALIM SI from Oracle eAM Asset
Update AssetWise ALIM SI from Oracle eAM Asset
Install AssetWise ALIM SI from Oracle eAM Asset
Dismantle AssetWise ALIM SI from Oracle eAM Asset
Install Oracle eAM Asset from AssetWise ALIM SI
Dismantle Oracle eAM Asset from AssetWise ALIM SI
Read WO in Oracle eAM from AssetWise ALIM
Create WO in Oracle eAM from AssetWise ALIM
AssetWise ALIM / MuleSoft
Bentley Integration Catalogue Code: BPI-ALIM-MULESOFT
Search AssetWise ALIM document by any document criteria
Return list of found documents in a form of BECS Web Page
Return list of found documents in a form of XML SOAP Response
Create Distribution Order and add related documents in AssetWise ALIM from MuleSoft
AssetWise ALIM / AIMS
Bentley Integration Catalogue Code: BPI-ALIM-AIMS
Retrieve new TAG data set from AIMS
Create new TAG from AIMS data set (by SyncSegments CCOM)
Retrieve updated TAG data set from ALIMS
Update existing TAG from AIMS data set (by SyncSegments CCOM)
AssetWise ALIM / CEMAR
Bentley Integration Catalogue Code: BPI-ALIM-CEMAR
Search for documents
Return search results
Create distribution order with documents
New transmittal on distribution order
Confirm transmittal creation
AssetWise ALIM / ALIM
Bentley Integration Catalogue Code: BPI-ALIM-ALIM
Catch ALIM Event
Retrieve Transmittal Details
Download Documents
Check Documents
Create Documents and Upload Files
Create Transmittal
Evaluate Results
BECS Packaged Integration for PlantSight
PlantSight / SAP
Bentley Integration Catalogue Code: BPI-PS-SAP
Create FLOC from new PlantSight TAG (ALIM)
Create Work Request in SAP system from PlantSight (AR)
Acknowledge the newly created Work Request from SAP to PlantSight (AR) (by CCOM)
Load WorkRequest(s) from SAP to PlantSight (by CCOM)
Load WorkOrder(s) from SAP to PlantSight (by CCOM)
Load Maintenance Plan from SAP to PlantSight (Solution Package)
Create new SAP FLOC from PlantSight
Update SAP FLOC from PlantSight
Read SAP FLOC Hierarchy from SAP to PlantSight
Create new SAP EQ from PlantSight
Update SAP EQ from PlantSight
Create PlantSight asset from SAP EQ (by CCOM)
Update PlantSight asset from SAP EQ (by CCOM)
Install PlantSight asset from SAP EQ (by CCOM)
Dismantle PlantSight asset from SAP EQ (by CCOM)
Install SAP EQ from PlantSight
Dismantle SAP EQ from PlantSight
Read SAP Notifications from PlantSight
Read SAP WO from PlantSight
Create SAP Notification from PlantSight (by CCOM)
Create SAP WO from PlantSight (by CCOM)
Show report of SAP Notifications in PlantSight PiP
Show report of SAP Work Orders in PlantSight
Show Asset Details from SAP in PlantSight
PlantSight / IBM Maximo
Bentley Integration Catalogue Code: BPI-PS-MAXIMO
Create Segment from new PlantSight TAG (ALIM)
Create Work Order in Maximo system from PlantSight (AR)
Acknowledge the newly created Work Order from Maximo to PlantSight (AR)
Load WorkOrder(s) from Maximo to PlantSight
Load Job Plan from Maximo to PlantSight (Solution Package)
Show report of Maximo WorkOrders in PlantSight
Show Asset Details from Maximo in PlantSight
PlantSight / Oracle eAM
Bentley Integration Catalogue Code: BPI-PS-ORACLE
Create Asset from new PlantSight TAG (ALIM)
Create Work Order in Oracle eAM system from PlantSight (AR)
Acknowledge the newly created Work Order from Oracle eAM to PlantSight (AR)
Load WorkOrder(s) from Oracle eAM to PlantSight
Load Oracle eAM Planned Work from ERP to PlantSight (Solution Package)
Show report of Oracle eAM WorkOrders in PlantSight PiP
PlantSight / MS SharePoint 365
Bentley Integration Catalogue Code: BPI-PS-SHAREPOINT
Upload document from PlantSight (ALIM) to MS SharePoint 365
Upload URL to document in PlantSight (ALIM) to MS SharePoint 365
Create Document attribute from PlantSight (ALIM) to MS SharePoint 365
Update document attributes from PlantSight (ALIM) to MS SharePoint 365
Update Document attribute from MS SharePoint 365
Show all SharePoint Documents for selected element in PlantSight
PlantSight / OpenText
Bentley Integration Catalogue Code: BPI-PS-OPENTEXT
Upload document from PlantSight (ALIM) to OpenText
Update document attributes from PlantSight (ALIM) to OpenText
Update Document from OpenText
Update Document attribute from OpenText
PlantSight / Documentum
Bentley Integration Catalogue Code: BPI-PS-DOCUMENTUM
Upload document from PlantSight (ALIM) to Documentum
Update document attributes from PlantSight (ALIM) to Documentum
Update document attribute from Documentum
FullText Search in Documentum for any file content from PlantSight
CheckOut Documentum document from PlantSight
CheckIn new revised document with updated attributes from PlantSight
PlantSight / OPC system (for example AspenTech IP.21, OmPro), Laboratory system (for example LIMS)
Bentley Integration Catalogue Code: BPI-PS-OPC
Display live Chart of Telemetry data from OPC system in PlantSight PiP (LIVE)
Display list of OPC metering points as a selector of chart data from OPC in PlantSight PiP
Display live Chart of sampled from Laboratory system in PlantSight PiP
Display list of Laboratory Sampling points as a selector of chart data from laboratory system in PlantSight PiP
Display list of metering points as a selector of chart data from OPC in PlantSight PiP
Display external data sheet in a form of formated table in PlantSight PiP
BECS Packaged Integration for iTwin
iTwin / SAP
Bentley Integration Catalogue Code: BPI-ITWIN-SAP
Start integration with SAP by select of 3D object (by BECS iTwin Extension)
Start integration with SAP button on iTwin viewer screen (by BECS iTwin Extension)
Create new SAP FLOC from iTwin
Update SAP FLOC from iTwin
Read SAP FLOC Hierarchy from SAP to iTwin
Create new SAP EQ from iTwin
Update SAP EQ from iTwin
Create iTwin asset from SAP EQ
Update iTwin asset from SAP EQ
Install iTwin asset from SAP EQ
Dismantle iTwin asset from SAP EQ
Install SAP EQ from iTwin
Dismantle SAP EQ from iTwin
Read SAP Notifications from iTwin
Read SAP WO from iTwin
Create SAP Notification from iTwin
Create SAP WO from iTwin
Attach document to SAP Notification from iTwin
Show report of SAP Notifications in iTwin PiP
Show report of SAP WorkOrders in iTwin PiP
iTwin / OPC system (for example AspenTech IP.21, OmPro), Laboratory system (for example LIMS)
Bentley Integration Catalogue Code: BPI-ITWIN-OPC
Display live Chart of Telemetry data from OPC system in iTwin PiP
Display list of OPC metering points as a selector of chart data from OPC in iTwin PiP
Display live Chart of sampled from Laboratory system in iTwin PiP
Display list of Laboratory Sampling points as a selector of chart data from laboratory system in iTwin PiP
Display list of metering points as a selector of chart data from OPC in iTwin PiP
Display external data sheet in a form of formated table in iTwin PiP
BECS Dynamic Packaged Integration for SAP
Bentley Integration Catalogue Code: BDPI-SAP
DataReading Projects
01 Read EQUI Details (SAP PM)
02 Read FLOC Details (SAP PM)
03 Read Work Orders (SAP PM)
04 Read Notifications (SAP PM)
05 Create Notification (SAP PM)
06 Create Work Order (SAP PM)
07 Read BOM (SAP PM)
08 Read Material Details (SAP MM)
09 Read Purchase Order (SAP MM)
10 Read Customer Details (SAP LO)
11 Read Vendor Details (SAP LO)
12 Read Billing Documents (SAP FI)
13 Read Project Phases (SAP PS)
Web Generator Projects for PiP
14 Generate WebPage with EQUI Details (SAP PM)
15 Generate WebPage with FLOC Details (SAP PM)
16 Generate WebPage with Work Order Details for TAG (SAP PM)
17 Generate WebPage with Notification Details for TAG (SAP PM)
18 Generate WebPage with Material Details (SAP MM)
19 Generate WebPage with Purchase Order List for Material (SAP MM)
20 Generate WebPage with Billing Document List for Customer (SAP FI)
21 Generate WebPage with Customer Details (SAP LO)
22 Generate WebPage with Project Details (SAP PS)
23 Generate WebPage for creating the Work Order for TAG (SAP PM)
BECS Dynamic Packaged Integration for IBM Maximo
Bentley Integration Catalogue Code: BDPI-MAXIMO
01 Read Asset Details
02 Read Job for TAG
03 Read Work Orders for TAG
04 Create Work Order for TAG
BECS Dynamic Packaged Integration for MS Dynamics 365
Bentley Integration Catalogue Code: BDPI-MSDYN
02 Read Devices for Asset
03 Read Alerts for Device
04 Read Alarms for Asset
05 Read Work Orders for Asset
06 Run OData Call
07 Create Asset
08 Display IoT Data for Asset
09 Display IoT Data for Device
BECS Dynamic Packaged Integration for AssetWise ALIM
Bentley Integration Catalogue Code: BDPI-ALIM
01 Read TAG Details
02 Read SI Details
03 Read Distribution Orders
04 Read Transmittals
05 Run eQL Query
06 Read Documents for TAG
07 Read Physical Files for Document
08 Create TAG
09 Update TAG Data
10 Install SI on TAG
11 Dismantle SI from TAG
12 Generate WebPage with Document List for TAG
13 Generate WebPage with Document Details for Document
BECS Dynamic Packaged Integration for AssetWise Asset Reliability
Bentley Integration Catalogue Code: BDPI-AR
01 Read Segment Details
02 Read Asset Details
03 Read Solution Packages for Segment
04 Run OData Call
05 Read APM Indicators for TAG
06 Read APM Alarms for TAG
07 Create Segment
08 Create Asset
09 Install Asset on Segment
10 Dismantle Asset from Segment
11 Generate WebPage with List of Indicators for TAG
12 Generate WebPage with List of Alarms for TAG
BECS Dynamic Packaged Integration for iTwin
Bentley Integration Catalogue Code: BDPI-ITWIN
01 Run iModel Query
02 Run iModel Bridge
03 Update Schema Attributes
04 Create Issue for Element
BECS Dynamic Packaged Integration for MS SharePoint 365
Bentley Integration Catalogue Code: BDPI-SHAREPOINT
01 Read Documents for TAG
02 Read Document Details
03 Open Document by Name
04 Upload Document to MS SharePoint 365
05 Update Document Data in MS SharePoint 365
06 Generate WebPage with List of Document for TAG
BECS Dynamic Packaged Integration for OpenText
Bentley Integration Catalogue Code: BDPI-OPENTEXT
04 Upload Document to OpenText
05 Update Document Data in OpenText
BECS Dynamic Packaged Integration for Documentum
Bentley Integration Catalogue Code: BDPI-DOCUMENTUM
04 Upload Document to Documentum
05 Update Document Data in Documentum
06 CheckIn Document
07 CheckOut Document
08 Generate WebPage with List of Document for TAG
BECS Dynamic Packaged Integration for Fabasoft
Bentley Integration Catalogue Code: BDPI-FABASOFT
01 Read Asset Documents
BECS Dynamic Packaged Integration for MS Excel
Bentley Integration Catalogue Code: BDPI-EXCEL
01 Read Excel Data
BECS Dynamic Packaged Integration for Senseye
Bentley Integration Catalogue Code: BDPI-SENSEYE
01 Read Sensey Cases
BECS Dynamic Packaged Integration for McHunter
Bentley Integration Catalogue Code: BDPI-MCHUNTER
01 Display Charts for Asset
02 Display Trends for Asset
03 Display List of Alarms for Asset
BECS Dynamic Packaged Integration for Datum360-PIM360
Bentley Integration Catalogue Code: BDPI-PIM360
01 Read PIM360 Documents
02 Display PIM360 Documents
03 Read Datum360 Asset Data
BECS Dynamic Packaged Integration for ProjectWise
Bentley Integration Catalogue Code: BDPI-PROJECTWISE
01 Read ProjectWise Documents
02 Display ProjectWise Documents
03 Download ProjectWise Documents
BECS Dynamic Packaged Integration for IoT
Bentley Integration Catalogue Code: BDPI-IoT
01 Read Azure IoT Data
02 Read 4D Analytics IoT Data
BECS Dynamic Packaged Integration for Google Street View
Bentley Integration Catalogue Code: BDPI-Google
01 Generate WebPage with Google Street View
BECS Dynamic Packaged Integration for Camera Feed
Bentley Integration Catalogue Code: BDPI-Camera
01 Generate WebPage with Live Camera Stream
Bentley integration catalogue
