General Intro
BECS Dynamic Packaged Integration (BDPI) is general enabling one step integration with unlimited amount of user enterprise systems from ERPs like SAP, IBM Maximo or IFS via DMS (SharePoint, OpenText, Documentum, ….) up to IoT, Spatial or GIS systems (ESRI, AutoDesk, Hexagon, …). Learn more about BDPI here and at "Mastering in BDPI" section here. The Step-by-step guide how to implement BDPI into your app is available in Downloads section at the bottom of this page.
Section structure
In this section you can find all needed knowledge in following structure:
General principle of BECS Dynamic (BDPI) adaptation
BECS Dynamic Integration is invented to offer universal integration gateway for your product to any of possible user systems. This platform is designed with focus on 3 major principles:
Thanks to all of those principles is implementation of BECS Dynamic in your product very simple and BECS will massively enhance your integration capabilities once for all.
Integration with your product will be working as shown on following schema:
General structure of BDPI interaction
There is expected to have 2 major flows implemented:
Supported types of BDPI interactions
Major interactions
BDPI supports 3 major interactions:
Interaction Name |
Brief Description |
Trigger initiating the call |
Expected visualization in your system |
Read the property data |
BDPI will read property data from integrated user enterprise systems. Property data are one unique set of attributes to selected object (for example “Asset Details from SAP for selected object”. |
Click on object in user solution |
Data are shown in “Property Window” in a form “Attribute – Value” |
Sample of result: |
Read multiline data |
BDPI will read multiline data from integrated user enterprise systems. Multiline data are list of rows (“table”) for selected object (for example “All documents from SharePoint for object”. |
Data are shown in “GRID Window” in a form of multirow table |
Sample of result:
Execute User Query |
BDPI will resolve query across all relevant user enterprise systems and return object identifiers which fits to the query result |
Finalization of query in some query builder |
Sample of result: |
Minor interactions (supportive calls for major interactions)
In respect of executing the major interactions we prepared also supportive REST API calls as follows:
Major interaction |
Support call |
Description of support call |
Result |
Read Grid TAB Names |
BDPI will deliver list of all TABs and its structure (fields) for featured GRID calls |
Json with a list of TAB Names |
Sample of Result visualization: |
Read attributes for Query Builder |
BDPI will deliver all attributes defined in BDPI for building the User Queries |
Json with a list of Attributes |
Read Value List for selected attribute |
BDPI will deliver Value List defined in BDPI for concrete Attribute (if exist), which can be used in building the User Queries |
Json with a Value List for concrete Attribute |
Interactions in detail
In following sections, you can find real detail of each interaction. Please understand endpoints and concrete data used as samples. Real usage in your project may vary.
In a call is needed to provide following json:
"returnAsXML":false,
"projectName":"PS_D_DISPATCHER",
"projectVariables":[
"name":"CODE",
"value":"0x30000001d11"
"name":"EventType",
"value":"PROPERTIES"
"name":"TabName",
"value":""
"name":"organizationID",
"value":"fab9774b-b338-4cc2-a6c9-458bdf7f966a"
"name":"iModelID",
"value":"a9ac27e8-793e-434c-9365-da069eac0ddb"
Attribute Name |
Attribute Description |
Values |
"returnAsXML" |
Switch using to define format of BECS Service response (json/XML) |
false – json true – XML |
"projectName" |
Technical Name of BECS Project executing relevant calls (please use only BECS project names listen in this document) |
PS_D_DISPATCHER PS_D_SEARCH_OBJECTS PS_D_SEARCH_OBJECTS PS_D_FILTER_FIELDS PS_D_VALUE_LIST |
"CODE" |
Unique identifier of selected object in your solution (object you want to ask data for) |
"EventType" |
Identification of BECS Interaction you want to run |
PROPERTIES GRID |
TabName |
Name of the GRID Tab Name you are asking data for (on which was clicked in your solution) |
organizationID |
GUID of caller’s Organization |
iModelID |
GUID of caller’s iModel |
"name":"CODE",
"name":"EventType",
"value":"GRID"
"name":"TabName",
"value":"SharePoint"
"name":"iModelID",
For reading all existing TAB Names for your featured Multiline data read you can use exactly the same call as described in previous section “Read multiline data”, just use blank TabName in input json (because in truth you do not know the TAB Name until reading them):
"projectName":"PS_D_SEARCH_OBJECTS",
"name":"condition",
"value":"<conditions><condition><field>Manufacturer of asset</field><value>A*</value></condition><coloredBy>Year of construction</coloredBy></conditions>"
"name":"iModelID",
"value":"b8c32999-e571-468b-9584-85cd1ae97369"
"value":"72adad30-c07c-465d-a1fe-2f2dfac950a4"
This input attribute is used for definition of user query, where query is always defined in following structure:
<condition>
<value>A*</value>
</condition>
Every condition has operator “EQUAL” only and between conditions is only “AND” operator.
BDPI supports one attribute selection for colouring of output in format:
BDPI sends payload in following structure:
Result brings for each found element:
Name of returned attribute |
Description (usability of attribute) |
"Code" |
Unique Element identifier (same as in input json) |
"color"
Color of element defined by BDPI according selected “coloredBy” attribute |
"GroupByValue" |
Identifier of value for this colour – recommended to use for Legend definition in your system |
"Blinking" |
Flag identifying request to blink for particular element |
"organizationUUID":"72adad30-c07c-465d-a1fe-2f2dfac950a4",
"projectName":"PS_D_FILTER_FIELDS",
"name":"iModelID",
This attribute identifies the integration section in which is this attribute to be able to distinguish same named attributes from different integrations (SAP EQ can have “Description” as well as SharePoint document or Maximo Asset…).
We recommend using this as a grouping attribute in your query builder.
"returnAsXML": false,
"projectName": "PS_D_VALUE_LIST",
"projectVariables": [
"name":"USER_NAME",
"value":"Manufacturer of asset"
"name":"TAB",
"value":"Equipment Data - SAP via BECS"
"name":"iModelID",
"value":"1ba3d302-e4b9-41fa-bd64-f4962a156fe6"
Read IoT TAB Names
"name":"CODE",
"value":"0x20000039f56"
"name":"EventType",
"value":"IoT"
"name":"TabName",
"value":""
"name":"iModelID",
Read IoT data
"name":"CODE",
"value":"0x2000002a89e"
"name":"EventType",
"value":"IoT"
"name":"TabName",
"value":"4D IoT data - Temperature"
"name":"iModelID",
Security
All of the calls are requiring using valid IMS TOKEN in Authorization section of Call Header:
To simplify your implementation, we prepared all of the calls in a format of PostMan import without IMS validation. We expect that this will streamline your implementation, but keep in mind that for productive usage only IMS TOKEN Authorized calls will be enabled on real BECS Cloud End Point. You can download the PostMan collection below in Downloads section.
Downloads
BECS5 vs EDF.postman_collection.json
Postman collection to use for your test
BDPI-Test-IoT-postman-collection.zip (clicking the link automatically downloads the file)
How to implement BDPI to your product (clicking the link automatically downloads the file)
