AssetWise and CMMS integrations - overview
Work management process
Click to view video in new window.
Pre-planned work - Work Requests - Work Orders
The work management flow uses both the Process-Acknowledge pattern as well as the sync pattern.
Asset and Segment published by CMMS
Follow this link to view this PowerPoint slide showing how Segment/Asset change or creation in the CMMS flows through the components to arrive in AssetWise.
The publishing flow uses the Sync pattern.
White paper: Integration architecture
The AssetWise Interoperability Overview document provides a technical review of Bentley's AssetWise interoperability service. You can find the documents for each released version of Interop starting from this link. The overview document includes information about
Installation Guide
