Tenant configuration user interface
The interop configuration UI is available for both on-prem and hosted environments.
On prem: if you are running remote desktop to the interop server, the URL can be
For a hosted environment, use the correct prefix for your deployment stage. Visit here for the base URLs.
Edge and Google Chrome recommended. Firefox is usually fine but if you encounter any display or login issues, try again Chrome.
