| Product(s): | eB Web | ||
| Version(s): | 15.5.x-15.6.x | ||
| Area: | Web Viewer | ||
| Subarea: | N/A | ||
| Original Author: | Gintautas Bajoriunas, Bentley Technical Support Group | ||
I am installing eB, and I want to be sure I am installing the correct plugins, when creating my web site
The Brava plug-in allows you to view uploaded files using browser without having additional applications installed on your local machine. Additional features which comes with Brava: Full text search, Publishing, Markup management.
Supported browsers: Internet Explorer, Firefox, Chrome Safari (we strongly recommend using only Internet Explorer as all eB features are supported only by this browser)
Supported formats by Brava
| Neutral Formats | Extension |
| Portable Document Format | |
| Content Sealed Format | CSF |
| Tagged Image Format | TIFF/TIF |
| CAD Formats | Extension |
| 000 HPGL Plot File | 000 |
| 906/907 Plot File | 906/907 |
| AutoCAD Drawing (2D) (through version 2014) | DWG |
| AutoCAD DXF (through version 2014) | DXF |
| AutoCAD Web Format (through version 2014) | DWF |
| CADKEY | PRT |
| Computer Graphics Metafile | CGM |
| GTX Group III, IV | G3, G4, CG4 |
| GTX Runlength | RNL |
| HP CAD ME10 (through version 13) | CMI, MI |
| HPGL Plot File | PLT |
| IGES (2D) (version 5.2) | IGS, IGES |
| Inventor (2D) (versions 5.3 - 2013) ** | IDW |
| MicroStation Drawing (through version 8.11, including XM, V8i) | DGN |
| MicroStation Group IV | CIT |
| MicroStation Runlength | RLE |
| MYRIAD 3D View Sets | MVS |
| OrCad (version 10) | DSN |
| Solid Edge Drawings (2D) (versions 8 - ST5) | DFT |
| SolidWorks Drawings (2D) (versions 97 - 2011) | SLDDRW |
| Imaging Formats (additional formats available*) | Extension |
| CALS (Group IV) | CAL, CG4, GP4, MIL |
| EDCARS | EDC |
| Encapsulated Postscript | PS/EPS |
| GIF | GIF |
| ISO 8613/CALS | ISO, CAL |
| JPEG Compressed Image | JPG, JPEG, JP2 |
| Portable Network Graphic | PNG |
| Tagged Image File | TIF, TIFF |
| Windows Bitmap | BMP |
| Additional Document and Image Formats* | Extension |
| Corel Draw | CDR |
| Corel Presentations | SHW |
| DataBase Formats | DBF |
| DocuWorks | XDW |
| FAX CITT Group 3 Fax | FAX |
| Hangul Word Processor | HWP |
| Hyper Text Markup Language | HTML, HTM |
| Microsoft Email | MSG |
| Microsoft Excel | XLS, XLSX, XLSM, XLSB, XLTX, XLTM |
| Microsoft PowerPoint | PPS, PPT, PPTX, PPTM, PPSX, PPSM, POTX, POTM |
| Microsoft Visio | VSD, VST, VDX, VSX, VTX |
| Microsoft Word | DOC, DOCX, DOCM, DOTX, DOTM |
| Microsoft Works | WDB, WPS, DOCX, XLSX |
| PageMaker | P65 |
| QuattroPro | WB1, WB2, WQ1 |
| Rich Text Format | RTF |
| Samna Word | SAM |
| Windows Write | WRI |
| WordPerfect | WP5, WP6, WPD, WPF |
| WordStar | WS |
*Some formats may require additional purchase
The Brava plugin is installed when selecting the 'Publish eB information for distribution and non-eB access' when creating your web site, as shown below.
After eB Web deployment it is necessary to go to the deployed virtual directory and modify a Brava setting in the web.config file.
Brava!® Enterprise 7.1 server
After installing Brava plug-in you should see new action "View File in Brava!" under Media options.
After launching Brava viewer first time you will be asked to install BravaClient, please select Install otherwise you won't be able to use Brava.
It should not take longer than half of the minute for file to load as viewer load each page separately. Loaded viewer with document should look as in screenshot below.
For more detailed instructions how to use specific Brava viewer functionalities read "eB Web User Guide".
Any licenses required by the Brava! software are obtained by the customer direct from Informative Graphics.
n/a
