| Product(s): | eB Core; eB Server;eQL;Reports | ||
| Version(s): | 15.04.01 and higher | ||
| Area: | eQL Reports | ||
| Subarea: | N/A | ||
Running some eQL reports in eB Web Client will yield error message : "Object reference not set to an instance of an object.". Same report will execute without errors in eB Director Client.
Reports that include in SELECT statement data under the Relationships---->Copies properties of a DOCUMENT that retrieve NULL values may cause this behavior. This is due to eB Web client interface trying to access a non existing rows in eB database table.
For example the following eQL will cause the error:
START WITH Document
SELECT
Code,
Revision,
Name,
State,
Copies.Files.Name,
Copies.Location.Code,
ApprovalStatus,
Id
WHERE
Code LIKE @Doc_No
AND Revision LIKE @Rev
AND Copies.CopyType = 'M'
AND IsLatestRevision = 'Y'
To retrieve these NULLs in eB Web Client please add the “TRIM” function to the SELECT column(s) that causes the error. In example above you want to add "TRIM" to columns "Copies.Files.Name" and "Copies.Location.Code":
START WITH Document
SELECT
Code,
Revision,
Name,
TRIM( Copies.Files.Name ),
TRIM( Copies.Location.Code ),
ApprovalStatus,
Id
WHERE
Code LIKE @Doc_No
By adding the TRIM you "force" eBWeb to retrieve all values (NULL or not) and then format them for display. Not having a TRIM makes eBweb retrieve and display at the same time which causes the error when no value is found for one of the columns.
