Applies To | |||
Product(s): | eB Information Manager, Assetwise CDE, Brava | ||
Version(s): | 15.x.x, 16.x.x | ||
Environment: | N/A | ||
Area: | eB-Brava | ||
Subarea: | Brava Mark Ups | ||
Original Author: | Roberto Garcia |
Question:
Where does eB/Brava store the markup xml files?
Answer:
Brava Markup files are stored in eB attached to an eB Copy object similar to the Copy objects that are linked to documents. The difference is that the Brava Markup copies are "hidden" from front end interface other than when you open the file in BRAVA.
