eB Director Reporting Learning Path
This Learning Path contains courses that will teach you how to create reports in eB Director for predefined searches and using the eB Query Language. This course teaches you how to prepare, create and organize eQL reports in eB Director and eB Engineering Designer.
eB Report Designer Basics:
1) eB eQL Reports: Understanding the Data Structure
2) eB eQL Reports: Getting Started in eQL
3) eB eQL Report: Building the Query
4) eB eQL Report: A Real eQL Query Example
Reporting on eB Data:
Learn the various reporting options available for acessing data stored in the eB Information Manager system. Accessing and presenting eB data in helpful and easy to use and understandable formats will enhance your system for the end user to your management team. You will have a chance to build and execute custom quick searches, autofiling folders and eQL reports. SSRS reports will be explained and demonstrated.
Constructing an eQL Search
