Product
| Product(s): | eB Information Manager | ||
| Version(s): | 15.x.x | ||
| Area: | User | ||
| Subarea: | Logon | ||
| Original Author: | Dennis Chan, Bentley Product Advantage Team |
Requirement:
Need to find out the logon activities of eB users.
Run the following SQL statement directly against the eB database (e.g. using SQL Server management Studio). Note that the query will show any logon activity with the oldest audit records first. If there is no audit record for the person, the last access date will be '1/1/1753'. (Credit to Eric Rajala.)
select *
from (
select p.person_code, Max(oai.action_date) last_access_date
from object_audit_info oai
inner join audit_info_defs aid on oai.action_type = aid.action_type
and oai.object_type = aid.object_type
inner join persons p on oai.person_id = p.person_id
where oai.object_type = 116
and aid.name in ('Logged On', 'Logged Out', 'Failed Logon')
group by p.person_code
) _
union
select p.person_code, '1/1/1753' last_access_date
from persons p
order by _.last_access_date
Workaround:
N/A
