Product
| Product(s): | eB Information Manager | ||
| Version(s): | 15.x.x | ||
| Area: | Basket | ||
| Subarea: | Send email | ||
| Original Author: | Dennis Chan, Bentley Product Advantage Team |
Problem Description:
When users attempt to register AdobePDFLWrapper.dll using the Regsvr32 command they get the following error:
The module "adobepdflwrapper.dll" failed to load.
Cause:
One or more files needed for AdobePDFLWrapper.dll to register successfully are missing.
Make sure the folder containing AdobePDFLWrapper.dll (typically C:\Program Files\Bentley\eB\Shared\Adobe) also has the following files in it:
ACE.dll
AdobePDFL.dll
AdobeXMP.dll
AGM.dll
ARE.dll
AXE8SharedExpat.dll
BIB.dll
BIBUtils.dll
CoolType.dll
icucnv36.dll
icudt36.dll
JP2KLib.dll
Workaround:
N/A
