Applies To | |||
Product(s): | eB SSIS | ||
Version(s): | 15.6.01, 16.x.x | ||
Environment: | N/A | ||
Area: | SSIS | ||
Subarea: | N/A | ||
Original Author: | Bentley Support | ||
The package failed to load due to error 0xC0011008 "Error loading from XML". This occurs when CPackage::LoadFromXML fails.
If you get the error from the ExecuteSSISPackage engine then try opening the package in BIDS. Sometimes it will give you more information. The error usually occurs when there are missing components that need to be installed. Ensure that the eB SSIS Components are installed. Also ensure that any custom or 3rd party components are installed. Some package use the following 3rd party components.
Microsoft Connector for Oracle from Attunity
http://www.microsoft.com/en-us/download/details.aspx?id=29284
ACE OLE DB 12.0 Provider
http://www.microsoft.com/en-us/download/details.aspx?id=13255
