HTTP Response Code is 500, not 2XX
Product(s):
Brava
Version(s):
15.5.1, 16.x.x
Environment:
N/A
Area:
Documents
Subarea:
Bulk Imports
Original Author:
Rich Thomas, Bentley Technical Support Group
Error or Warning Message
Failed to save markup.
HTTP Response Code is 500, not 2XX.
Unknown
Explanation
I am viewing a file within Brava.
I add a stamp, and click save.
I receive the error:
Unknown
Root Cause:
Due to a stamp that was added to the file externally, it does not allow Brava to read the file.
How to Avoid
With any issue like this, please examine the txt file:
C:\Users\<user.name>\IGC\x7_1\clientlog.txt
On this occasion, the stamp is a red herring, the error will appear when saving any markup.
1.Takeout the file from the system and  stamp needed to be flattened in order for Brava to open the file.
2. The issue can be related to incorect scope.  The eB configuration did not allow markups to be saved within the global scope, only the sub-scope.
3. Permission issue on Document. User must have modify permission on Document for markup to be saved.
N/A
