Applies To | |||
Product(s): |
eB Director | ||
Version(s): |
16.x.x | ||
Environment: |
N/A | ||
Area: |
Attributes | ||
Subarea: | |||
Original Author: |
Padma Kanadi, Bentley Technical Support Group |
Requirement
How to fetch list of values from one attribute to another
create 2 attributes,
when you have 2 attributes, go to the first attribute and click on the ellipsis(three dots highlighted in the below screenshot), enter all the details and test connection.
Next go to Query-> copy the query highlighted. Fyi- that’s just an example query
Now paste this into the second attribute, by going to second attribute- > ellipsis-> query-> paste in the query -> Test query
A pop-up will appear click ok -> Current values- > the fetched values will appear here. If not click refresh they will appear.
