Product
| Product(s): | Nuclear Engineering Designer | ||
| Version(s): | 5.3.x.x | ||
| Area: | Login | ||
| Subarea: | |||
| Original Author: | Dennis Chan, Bentley Product Advantage Team |
Problem Description:
User gets the following error while trying to login to Nuclear Engineering Designer (NED):
"The ProtoProxy is already set, you may not replace it with another. Dispose the Session and create another."
Cause:
This is known to be an error caused by some license management tool issues.
Fix the license management tool issues first. Then re-try the login.
Workaround:
N/A
