Product
| Product(s): | Assetwise ALIM | ||
| Version(s): | 16.7.xx | ||
| Area: | eB System Management Console | ||
| Subarea: | Community Configuration | ||
| Original Author: | Dennis Chan, Bentley Product Advantage Team |
Problem Description:
User gets the following error when attempting to run Director or access a community in eB System Management Console:
- Activation of app Microsoft.Windows.Cortana_cw5n1h2txyewy!CortanaUI failed with error: This app can't be activated by the Built-in Administrator. See the Microsoft-Windows-TWinUI/Operational log for additional information.
Cause:
This error has occurred in a community where it was not enabled (in the eBSMC) by the built-in ADMIN account.
- Run eBSMC
- Click the Community node
- Right click the community in the window
- Select Delete Community
- Add the community again and specify the ADMIN user to enable the community
Workaround:
N/A
