Applies To | ||||
Product(s): |
eB Classic Web | |||
Version(s): |
15.x.x, 16.x.x | |||
Environment: |
N/A | |||
Area: |
Report | |||
Subarea: |
N/A | |||
Original Author: |
Nitin Bhui, Bentley Technical Support Group |
Problem:
Getting error while Downloading the Report Result in Excel. The error says ‘I’m Sorry, an error occurred. Error Executing child request for CSVReportDownload.aspx’
Error:
Steps: Run the Interactive report.
Click on the 'Download all result'
then you get the Child request error
Below is the EQL query
START WITH Event
SELECT
Code,
Name,
Documents.Document.Code,
Documents.Document.Revision,
Documents.Document.Name,
WorkTasks.WorkTask.Status,
FileContainer.Document.Files.Name
WHERE
Code LIKE '%-A-%' AND Projects.Project.Code = '5'
Workaround: In this case, we are getting this error because there is one document Title contains special character at the end.
How did we identify there is a problem with Document Title?
We executed the EQL query by removing one SELECT element at a time from the Query.
When we removed the Documents.Document.Name from the EQL and Executed report from Web and we were able to download the result.
So further we checked the associated Documents Title and found out that the document contains one special character at the end.
We removed the special character and executed the report and were able to download the result.
