Product
| Product(s): | Assetwise ALIMweb | ||
| Version(s): | 16.7.43 | ||
| Area: | User Preferences or System Preferences | ||
| Subarea: | |||
| Original Author: | Dennis Chan, Bentley Product Advantage Team |
Problem Description:
User gets the following error when attempting to open user preferences or system preferences:
- The Id is <1. Use the overload to pass the Id or set the Id first.
Cause:
This is a known issue related to the user's permissions. SR 7001070656 has the details.
A fix is available from version 16.7.53.
Workaround:
N/A
