AssetWise CDE CONNECT Edition 16.7.25
AssetWise CDE 16.7.25 is available on CONNECTServices Online and can be downloaded from https://softwaredownloads.bentley.com/ under Product Line>Infrastructure Asset Management, Brand>AssetWise or use the following SELECT Direct Link :
https://softwaredownloads.bentley.com/en/ProductDetails/1900
From the list select version 16.07.25.05 under AssetWise CDE (eB Platform) as shown in screen below:
Click here to download the ReadMe.
AssetWise CDE (eB Platform) provides identification and classification of information object types. AssetWise controls information throughout the lifecycle of change - ensuring the delivery of relevant, trusted information in context - to infrastructure operations, where and when it is needed. The ability to export or publish information outside the system for other systems or external parties to consume is provided. It provides change management services for documents, organizations, requirements, and other information types where change management best practices apply.
NOTE: This will be the last release with the AssetWise Classic Web UI. AssetWise ALIM Web UI, delivered in a separate download (AssetWise ALIM Web CONNECT Edition), will be replacing the Classic Web UI.
This release delivers the core server, two most popular clients and a number of web connectors, but not limited to:
Applications and web plug-ins included
What's New
A number of clients and connectors are removed from this release, those components are:
Updated Platform and Version Support
For additional information on release notes and system requirements see the Readme document.
