Error Description
Error writing node Conversion Factor from reader info with key PysicalItems.uni.ConversionFactor on procedure ebpnew_get_physical_item with option Header. Input string was not in a correct format
Steps before error
On creating a new Physical Item or opening an existing Physical Item.
- Log onto the eB Server as the eB Service account that has “Log In As Service” access – it will be the user account that is used to start your eB Services
- Open Regional Settings and change:
- Language to English UK
- Decimal Symbol to period (i.e. .)
- Digital grouping symbol to period (i.e. .)
- Restart the eB Service Manager Services in computer management
- Logon to Director and try creating work order
