Product
Applies To | |||
Product(s): | Assetwise ALIM | ||
Version(s): | 16.7.xx | ||
Environment: | N/A | ||
Area: | eB System Management Console | ||
Subarea: | Snapshot Capture Queue | ||
Original Author: | Dennis Chan, Bentley Product Advantage Team |
Problem Description:
User gets a failed snapshot capture queue job in the eB System Management Console with one of the following errors:
- Failed to render to PDF - Error : HTML render is blank.
- Failed to render to PDF - Error : Unable to render HTML. Failed to configure MSHTML engine due to the registry value "Software\Policies\Microsoft\Windows\CurrentVersion\Internet Settings\Security_HKLM_only". Please refer to the "MSHtmlBootstrap" option for an alternative configuration method.
- Unable to render HTML. Failed to configure MSHTML engine due to the registry value "Software\Policies\Microsoft\Windows\CurrentVersion\Internet Settings\Security_HKLM_only". Please refer to the "MSHtmlBootstrap" option for an alternative configuration method.
Cause:
The issue is likely a security policy preventing the automated change of certain IE11 internet options in the registry for the service user.
- Run regedit on the ALIM app server
- locate and set the following two registry keys:
- HKLM\SOFTWARE\Policies\Microsoft\Windows\CurrentVersion\Internet Settings\Security_HKLM_only = 0
- HKLM\SOFTWARE\Policies\Microsoft\Windows\CurrentVersion\Internet Settings\PreventIgnoreCertErrors = 0
- Save and close regedit
- Run Internet Explorer
- Go to Internet Options
- Under the Advanced tab check the box which says "Allow active content to run in files on My Computer"
Workaround:
N/A
