| Product(s): | Assetwise ALIM | ||
| Version(s): | ALIM 16,7.60 and higher | ||
| Area: | eQL Reports | ||
| Subarea: | N/A | ||
Some Fixed value attributes might be marked as Obsolete/Inactive and user wants them to be excluded from being selected in eQL Search/Report.
Cause for this issue is that Using Default eQL for search lookup value list does not filter inactive values.
The following example is for a Fixed Value attribute named "DIVISION". You may use the same steps below and replace "DIVISION" with the attribute name you chose. Yo can also add additional filtering as allowed by valid eQL WHERE clauses.
1. In the Define Parameters step, under the Available Values Tab for the desired attribute, select the option "Get Value from a Search":
2.Replace the default search shown in eQL editor section with the following. You can replace "DIVISION" with your desired attribute:
START WITH Class
SELECT
Attributes.AttributeDef.AttributeValueList.Value col1,
Attributes.AttributeDef.AttributeValueList.Value col2
WHERE
Attributes.AttributeDef.Name = 'DIVISION'
AND Attributes.AttributeDef.AttributeValueList.IsObsolete = 'N'
