| Product(s): | APM Implementation and Performance Management | ||
| Version(s): | All Versions | ||
| Environment: | SQL Server | ||
| Area: | Database Performance | ||
| Subarea: | N\A |
How to detect and resolve Database Index fragmentation
SELECT OBJECT_NAME(OBJECT_ID), index_id,index_type_desc,index_level,avg_fragmentation_in_percent,avg_page_space_used_in_percent,page_countFROM sys.dm_db_index_physical_stats(DB_ID(N'YourDBName'), NULL, NULL, NULL , 'SAMPLED')ORDER BY avg_fragmentation_in_percent DESCWeekly Maintenance:
Rebuild indexes where avg fragmentation is >30%. This is recommended to be done on a weekly basis. Exclusive access is required for defragging.
